Locustworld mesh networking wiki has 150 entries at Scratchpad.wikia.com
Oct 19, 2007 0 Replies
Mesh networking is a technology that implements an Ad-hoc routing protocol such as [[AoDv]] using an
. AODV - Open distance vector routing. See
wiki details the mesh networking of
. A meshbox is either a Gateway
or a
. Plug one box via it's ethernet cable into an Internet connection. This box is the gateway and can be assigned a
the host PC with the Internet signal does not hand out a
lease. From the gateway make certain you can surf the web. Issue "getandverify" or "leachtest" command. The second box is the repeater. Allow 5min for the repeater to mesh, it will check into
.. See
and
