IE options - "never dial a connection" doesnt stick - returns to "Dial whenever a network connection is not present"
Mar 08, 2006 2 Replies
I am running Windows XP. Lately, I keep getting a dial-up connection popup window, even though I connect through the internet mostly through my wireless card. I go into Internet explorer and select the option to "Never Dial a Connection". A few minutes later, the settings go back to the selected option of "Dial whenever a network connection is not present" I did a thorough scan using Adaware and Yahoo anti-spy, used the program Hijack-This to search for unusual items, yet didn't find anything. Does anyone have some insight to what the cause may be? Thanks
Are you also running Ad-Watch?
What other anti-malware apps might you be running which may be disallowing the change (e.g., Spybot, SpywareBlaster, Spysweeper, Zone Alarm Pro)?
