Going the next Quarter Mile...
Jan 21, 2007 5 Replies
Jump to replies (5)
I would like to get a wireless signal over to another location about a quarter mile (about 1500 feet) from here. That's the good news.
The bad news is its an obstructed path. There are a couple of wood frame structures in the way. Going over the top might be practical on one end, but not the other. So...
Since its a fairly short path as paths seem to go, can I just "brute force" a signal over there? Or does this path fail even the "laugh test"?
A 22 dbi gain grid antenna and signal booster is more than reasonable on this end. A flat panel antenna out the second story window, and even an amp on the other is possible. Can this work?
Thanks for your thoughts,
Dennis
Depending on exactly how much you have to go thru you might look at some of the 900Mhz data radios out there.. they penetrate obsticals alot better.
Thanks Adair...I browsed the net and am suffering sticker shock :)....
$1000/pair of 900mhz data radios seems to be typical...am I looking in the wrong place?
for example...
and
Suggestions welcomed...
Dennis
Can you go around using two hops.
Perhaps a repeater at mid-point?
snipped-for-privacy@gmail.com hath wroth:
900MHz has it's own collection of problems. I've had quite a bit of experience dealing with the long dead Metricom/Ricochet 900MHz radios. 900MHz will go quite nicely through a forest. It will NOT go through a building, brick wall, or hill side. NLOS is science fiction.
Maxstream and Freewave radios have about 100Kbits/sec max thruput. They are intended primarily for SCADA and data telemetry, not ISP service. I suspect you might find this a bit slow.
For more speed and something more suitable, see:
(WaveRider)
The Waverider hardware was originally designed for long range ISP service in forested areas.
You won't like the prices.
One 900MHz AP and two clients for only $3,000.
