etherant ll LR help
Feb 02, 2008 1 Replies
I have an etherant ll lr that was working but the cable to the antenna broke I think something or some one pulled on it It broke about 6 ft down from the top of the 60ft tower any way i can't link up to the acess point It says it is not associated does someone know how to trouble shoot these or fix them I re flashed the firm ware and reinstalled all the settings but no luck Ican punch in all the numbers but it wont work on the wireless side There is not support anymore for this antenna
Have you opened it up and checked to see if the wireless card has been dislodged? There is a picture with the card removed here:-
might be worth trying another wireless card in the slot.
