And the sky might fall on our heads - some folk just aren't happy without something to worry about.... :-) It's even funnier when you see some chain smoker complaining about mobile phone masts - clueless... Guy
Articles yesterday in the British press raised again concerns relating to the hazards arising from DECT phones and their continuous microwave emissions.
Should similar concerns apply to a home with several WiFi routers in, 'pumping out' 2.4GHz 24/7??
Newest Airport Regulations Bring Nnew 'Security', Delays By DANICA...
B
Bigguy
Guy
M
Mark McIntyre
Crivvens. The articles probably appeared in the National Enquirer and the Sunday Sport.
Similar concerns should indeed exist. Which is fine, since the sensible concerns level for DECT phones is zero.
But if it worries you, wear a tinfoil hat... :-)
Mark McIntyre
D
Derek Broughton
Uh-uh! Some folks at MIT (iirc) actually researched the effects of tinfoil hats on radio waves. They found that you got higher energy levels _under_ the tinfoil hat than you did if you didn't use one :-)
_
__spc__
[snip]
Eeek - aluminium foil? Alzheimers, no?! ;-)
M
Mark McIntyre
I'd love to work somewhere that gets grants to do this sort of research. I mean ,can you imagine the application form, or the interview board? :-)
Mark McIntyre
M
Mark McIntyre
Only if you eat the hat,
Which is perfectrly reasonable I guess......
Mark McIntyre
D
Doz
This makes sense .. the "hat" is a parabolic reflector.. it concentrates the radio waves into your head... nice
D
Derek Broughton
I'm sure they did it on their own time :-) Also, iirc, they actually tested tin vs aluminum foil. I can't remember how that worked out.
B
Bob II
8>>
Very tongue in cheek.
your own:-
J
Jeff Liebermann
Derek Broughton hath wroth:
On the Effectiveness of Aluminium Foil Helmets: An Empirical Study
calibrated antennas. No field measurements. No specific absorption models. No NEC2 or NEC4 models. No grandoise conclusions. No inflamatory comments about other researchers. No footnotes. No requests for additional funding. Obviously, this is not a professionally prepared research paper, is incomplete, and is a disgrace to the American higher educational system. Also, the math is seriously deficient as the obsolete Agilent 8714ET network analyzer was only about $35,000 new (with a typical options mix) and not $250,000. Disgraceful, methink.
D
Derek Broughton
LOL. Thanks for the link - I just knew about this from a radio interview.
B
Bob II
I would like to have seen the presentation for the budget for this
Bob
Report Content
ASAP.
