Create Wireless network between 2 WRT54GS's
Jan 22, 2005 1 Replies
Jeff Liebermann is right.I want to connect two WRT54GS via wireless at
distance 300 meters each other with 2 California 120 Antennas Vertical
Polarisation.I use WDS and make everything normal.My configuration is
this:
PC1(switch&internet)-->WRT54GS----wireless
300m--------WRT54GS-->PC2(clients&laptop)
Not all routers can do this. You need ones capable of acting as bridges. Check the spec for the one you have, and then read the manual to see how to put them into bridge mode. Note that once in bridging mode, some routers cannot also be APs (tho some can do both simultaneously).
