Buffalo WHR-HP-G54 vs. Microsoft MN-730
Nov 23, 2006 5 Replies
Jump to replies (5)
Hi, After flashing with dd-wrt, v23SP2 firmware, set up another wireless network which has PC laptop, Powerbook and desk top. All works without problem but this MN-730 adapter in a desk top. It sees the router but won't connect no matter what. (used to work well with Linksys WRT54GX2 before). Is there any known compatibility issue with this particular card? TIA, Tony
On Thu, 23 Nov 2006 16:37:11 GMT, Tony Hwang wrote in :
Turn off _all_ security to start troubleshooting. Turn security back on once you get it working.
Hi, It's puzzling. If I set the router wireless mode to -11g only this particular card won't work. If I set it to mixed(-11b and -11g), then it works. Wonder why? Tony
On Fri, 24 Nov 2006 06:38:04 GMT, Tony Hwang wrote in :
Is the card b-only, or configured for b-only?
Hi, This is one of the early -11g card based on Broadcom chip. It is configured to run on -11g on device manager setting. Tempted to try another card such as Linksys or Buffalo.
Hi, Further fiddling at the card side, if I set the TX preamble from Long to auto, all is well as it should. Tony
