500mw booster
Jul 11, 2007 1 Replies
500mw booster open original image
ok so i got 1 ov these alfa cards 'Data-alliance.net Alfa 500mW USB Wireless B/G Adapter with RP-SMA Antenna Jack'
is a big improvment next i got a yogi 17dbi anntenna 'eBay.co.uk: NEUE Yagi Antenne 18 dBi mit 3 Meter / RP-SMA (item
280132196560 end time 12-Jul-07 23:40:16 BST)'
improved more now i want to add a booster but cant get any info about it so how much distance would this booster add? 'eBay.co.uk: 802.11b WiFi Amplifier Booster 500mW - 27dBm WiFi (item
270121261380 end time 16-Jul-07 03:41:28 BST)'
for any help
Fraid it's probably not as cheap as stuff on ebay, but you may want to look at this 500mw booster and indoor panel antenna (probably works with the yagi you already have)
CA2400A Wireless LAN Booster Package for 802.11(b) and 802.11(g) systems $299.99
CA2400A comes with:
500mw 2.4 GHz Bi-Directional Amplifier CA-P2000 Panel Antenna 14' low loss cable with connectors attached ( or optional different cabling) Your choice of adapter
