I'm having problems with a 3com wireless broadband router, OfficeConnect
3CRWDR100A-72 and two usb 3com clients, 3CRWE254G72. All are updated with the latest firwares and software under XP SP2. WPA is enabled.
If we are playing a game over the lan the network will crash with a cannot connect message, usually within 10 minutes but sometimes is ok.
Sometimes, when i'm just on the internet the computer will just freeze or i get a BSOD saying there was a problem with the driver of the usb client. In both cases i have to reboot. These will happen once every few days.
If i use a p2p network it will always fail within a couple of hours.
I've tried disabling the router firewall and using the XP one but still no luck.
Does anyone know what else i can try (apart from buying a new network?)
