3 Access Points in 1 DHCP
Dec 11, 2006 1 Replies
Hello.I have this problem: I have 3 Linksys in 1 building-2 floors and i have a DHCP.But when a new device want to have e-net i assign it in the 3 networks.My thought is that i want to connect the 3 DHCP in one and when i assign in whatever dhcp,when the client moves in other floor also to have access to e-net....Please help!
Are the linksys devices routers?
If so, disconnect the devices temporarily from the network and do the following:
1) Change pulic IP address of all but one router
Router A: 172.16.88.88 Router B: 172.16.88.89 Router C: [leave the same]
2) Change the internal IP address to be in the same range [Assume your internal IP space is 192.168.93.xxx]
Router A: 192.168.93.2 Router B: 192.168.93.3 Router C: 192.168.93.1
3) Disable DHCP on all but one router
Router A: Disabled Router B: Disabled Router C: Enabled
4) Plug the devices back into the network:
Router A: Plug into LAN port Router B: Plug into LAN port Router C: Plug into WAN/Internet port
Any wireless clients should now pull an IP from the LAN, and allow for roaming between the networks.
That being said, this is a less-than-proper way to design a network. You really need to have "Access Points".
Chris
- - - - - - - - - - - - - - - - - - - - Christopher M. Hutchison, CEO NetSteady Communications, Ltd.
Phone: 614-255-5575 Mobile: 614-853-0091 Skype: wifi_chris
