VoIP gateways
Aug 06, 2004 3 Replies
Jump to replies (3)
VoIP gateways open original image
Hey,
I've just started playing with VoIP from Pipecall and I'm generally impressed. The call quality is acceptable and the rates are exceptionally good and the incoming 0845s are perfect for our small business.
With my entrepreneurial hat on, I'm keen to explore VoIP further, particularly as I can see a market niche. I can appreciate that setting a fully-fledged VoIP infrastructure is completely beyond me, particularly financially. However I am interested in how I could utilise provide VoIP by either reselling or setting up a virtual infrastructure (using gateways etc).
I have done some very initial research and read up on SER. Setting up the SIP side of things seems achievable however I am almost stumped when it comes to the SIP -> PSTN gateway. Well, I say stumped, but I'm just not sure who to approach with regard to buying in these services, particularly as I'm not wishing to purchase on an enterprise level.
Can anybody recommend any services that might be good for me to investigate? Are there any suppliers on the newsgroup that can get in touch with me?
Thanks in advance.
Regards, Matthew Bates
Take a look at asterisk
as a gateway
I take it that you are in UK...
The following all run two way UK centric SIPPSTN Gateways:
Gossiptel (
Call UK
) [Also runs FWD UK PSTN Gateways]
Gradwell
SIPCall
So do we, with 0845 or geographic numbers:
InterViVo
Cheers,
Mark.
