VoIP GSM Gateway - HG-4000 Series
Hypermedia Systems announces the launch of a new VoIP GSM Gateway product - the HG-4000vs VoIP GSM Gateway for the GSM termination market.
Hypermedia Systems VoIP GSM Gateway for UMTS, GSM, CDMA and E1 / T1-PRI are the leading professional equipment for total connectivity solutions. The HyperGateway VoIP GSM Gateway line of products provides a tailor-made solution for SMEs (small and medium-sized enterprises), alternative carrier call termination and for call origination providers.
One of Hypermedia VoIP products which have been recently launched, called HG-4000vs, also belongs to the Gateway family.
HG-4000vs supports H.323. It is a complementary product to H.323-based IP equipments and supports up to 72 GSM ports. By using HG-4000vs there is no need for any external VoIP Gateways such as Cisco or Quintum.
HG-4000vs VoIP GSM Gateway main features:
From 16 to 72 GSM ports
Up to 288 SIM cards Advanced LCR and routing groups IP address and DDI pattern restrictions Remote pre-paid SIM recharge Integrated antenna splitter GSM worldwide use (850MHz / 1,800MHz / 1,900MHz) Redounded power supply WEB management and control The HG-4000vs VoIP GSM Gateway fixed cellular terminal can be used not only as a GSM Gateway but also for UMTS and CDMA (850 / 1900).
For more information on this company:
