SIP clarifications?
Oct 08, 2004 2 Replies
Phil McKerracher
An "application" is typically a program running on a PC or in a phone that interacts with the user. In this case, the user would control the call somehow by instructing the application, for example by lifting a handset or clicking a mouse. SIP doesn't care how this is done…
SIP is supposed to be an "application layer control protocol" in the RFC. What exactly does the phrase mean? What is a control protocol and what is an application layer control protocol? Could someone give examples?
Secondly, the RFC says SIP is not a vertically integrated communications system. I am interpreting this statement to mean that SIP does not provide details of every layer of the protocol stack, and different solutions for these layers can be mixed and matched to provide a functioning communications infrastructure. Am I right?
An "application" is typically a program running on a PC or in a phone that interacts with the user. In this case, the user would control the call somehow by instructing the application, for example by lifting a handset or clicking a mouse. SIP doesn't care how this is done, because that detail is "above" the application layer.
The particular format and timing that SIP uses for the control information is the "protocol". The messages would typically be carried over an IP connection, but SIP doesn't really care if they go by carrier pigeon or smoke signals, because this mechanism is "below" the application layer.
Also, SIP doesn't care how the voice information is carried once the call is set up. It would typically be in an RTP session but this detail is also outside the application layer. All SIP specifies is how to initiate a session, hence the name.
Right.
Thanks Phil.
Cheers, SH
