PRI b-channel LCKO problem between Cisco VOIP Gateway and Nortel 61C
Apr 20, 2005 1 Replies
Hi, I have a PRI between a Nortel 61c and a Cisco VOIP phone system. It allows us to 4-digit dial between the two phone systems. The PRI terminates into a 6608 gateway blade in our 6509 chassis system on one end and a PRI card in the Nortel (loop2) on the other. Every couple of months, I would have to disable and re-enable Loop 2 because the b-channels get locked out. Finding out why the channels go LCKO was not a big issue at the time because it didn't happen any more often than the b-channels on two other PRI's. We recently deployed 7 Cisco VOIP wireless phones in a manufacturing area with two Cisco access points and now I have to disable and re-enable Loop 2 every other day. I noticed on my Nortel terminal one morning an error referencing the loop and the channel and reason 44. Does anyone know what causes b-channels to LCKO? Does anyone else have any experience with this type of problem?? Thanks in advance. CAsniffer
on the nortel pbx lcko means locked out, another term is high and dry. Which means the nortel pbx did not see any release messages from the far end.
