Asterisk IVR has very poor voice quality
Sep 06, 2005 3 Replies
Jump to replies (3)
For comparison purposes, I set up two very similar IVR systems. One is a traditional IVR based on a Dialogic voice board while the other is a software-only IVR based on Asterisk.
The quality of the voice in the Asterisk IVR is awful.
If I add some hardware, will the quality improve??
-Ramon
"Ramon F Herrera" wrote in news:1126059491.007757.66840 @g43g2000cwa.googlegroups.com:
You can add a zaptel compatible card or use ztdummy. This should improve your quality.
Why even add hardware? Is there a problem with using the Dialogic hardware under Asterisk?
--kyler
There is indeed a problem using Dialogic hardware under Asterisk. For obvious reasons, the hardware support is extremely biased toward Digium boards. The Dialogic support is somewhere between "lacking" and "none".
-RFH
