Are all SIP softphones created equal (and will they work with Mitel) ?
Apr 01, 2005 6 Replies
Ian
AFAIK They have not launched the SIP gateway yet. So NO the 3300 is not SIP compataible, Who told you it was? Mitel do do 2 Sip compatable phones but the 3300 is not a SIP switch AFAIK. (And I work with it all the time) The SIP gateway will be coming and they did do a sip…
Are all SIP softphones created equal (and will they work with Mitel) ? open original image
Looks like we are finally moving ahead with a Mitel 3300 and are looking into options. Unified messaging, faxing, softphones are all very expensive. Mitel is SIP compatible so will any third party SIP softphones work with Mitel. Any recommendations?
thanks
Hal
AFAIK They have not launched the SIP gateway yet. So NO the 3300 is not SIP compataible, Who told you it was? Mitel do do 2 Sip compatable phones but the 3300 is not a SIP switch AFAIK. (And I work with it all the time) The SIP gateway will be coming and they did do a sip system, The 3300 uses MINET as its VOIP protocol. I would go back to the person who told you it was sip compatible and Ask them to demo it to you. Dont be supprised when they decline to.
IAn
Actually I assumed it was because they list all their phones as SIP phones. I will have to research it more. Any idea when their gateway is coming out?
thanks
Hal
Try one of the free SIP softphones from
or
. Let us know what you find out!
AFAIK only the 5215 (I have one in front of me connected to my Asterisk) and 5220 are dual boot. and I belive the Navigator also supports SIP. As to when the gateway will be avalible not sure and Mitel are getting good at late delivery. Its I believe its for terminating SIP not for sip sets. But when I saw it, It was in concept stage..
Ian
Even with out trying them I can tell you they wont work. The 3300 uses Minet as its protocol.
Ian
I would be surprised if Mitel had proper sip compatibility. Definitely not from what we've seen.
Why don't you go for a true sip-based ip pbx?
