What? In Finland if you call 100 minutes you pay as low as 7,56 cents a minute. With 1000 minutes it is as low as 3,58 cents a minute. That's to land lines or to any mobiles and at any time. We typically do not have cheaper calls on nights and weekends. Those are typical in countries where mobiles are still associated into business use and in off hours there is more free capacity. The network operators charge same regardless of the time so if cheaper calls on evenings are provided it is for the service operator to pay the difference and hope one gets it back on the more expensive daytime calls.
So could you give what someone making 100 minutes of calls would pay in the U.S.? More than 7,56 a month?
You mean free with no monthly fee? That's a good deal. In Finland we are talking about 10 cents a call + 1 cent a minute. The monthly fee is around 10 euros.
In general it is hard to mix the systems. One had to choose either one for a country.
In Finland one operator tried such a scheme but the land line operators refused to give the numbers to the mobile operator as the law did not force them to do so. Well it was not a true porting but one got two numbers, the old land line and a mobile number. One could receive calls through either (at predictable costs to the caller) but the receiver saw only the mobile number. (so basically it was an call forward done by the operator at no cost to you)
Also we used to have so called city phones with land line numbers. They could only be used locally in the particular city. They have since been discontinued. (At least in Helsinki). Those had a problem of very expensive calls to mobile phones.
Osmo
