4 numbers, 4 voice mail, on VOIP ??
Oct 06, 2005 7 Replies
ukcats4218016
I don't know of any that offer four. However, SunRocket offers two that ring into the same phone. They can be assigned different area codes if need be.
4 numbers, 4 voice mail, on VOIP ?? open original image
Can something like this be done, cheaply. What would be the best way, is there a nice SIP phone that could handle something like this?
  1. Ability to have 4 phone #'s come into a single phone.
  2. Have capability for the operator to know which phone number is ringing prior to picking up.
  3. Separate voice mail box for each #.
Thanks.
The Sipura 3000 ATA can be expanded to handle four lines. Voicemail is up to the VoIP service provider. Alternatively you need Asterisk software on Linux server with FXS / FXO phone ports. Regards, Martin
The Fritz!Box Fon from AVM
has 2 phone ports but has capacity for up to 10 SIP accounts, you can tell it to ring any phone for any account, but I don't know of a way to tell which account is ringing if you have more than 3. I have a/c 1 ringing phone 1, a/c 2 ringing phone 2 and a/c 3 ringing them both together.
Ivor
Sure.
Sipura SPA841 ip-phone can be upgraded to handle 4 lines (as standard 2) - or if you find one with old firmware if can easily be made to handle four without unlocking it ;-) - my two devices does it!
No problem
All my provideres provides the voicemail on the server. That way you don't have to think about loosing power etc on your phone.
IMHO a much better solution.
With asterisk and a provider like sixtel
you can do it. They have tons of numbers to choose from including toll free. I use them myself, support is pretty good too.
But Asterisk requires a PC to be on all the time, which a lot of people, myself included, don't want. I prefer a dedicated hardware box.
Ivor
With the device you need a provider that runs software+hardware to support it, with asterisk you can maintain it yourself and not have to wait for someone else to do it. I don't see the problem with leaving a computer on 24/7, my asterisk machine never crashes or needs restarting, it runs on a server dedicated to asterisk.
