hide callerid
Oct 08, 2008 1 Replies
Hi
In the UK BT is the biggest network provider and they do provide a range of CallerID related services.
For example you can prefix 141 to a dial string to hide the CLI.
Is this service common with other operators in other countries? In a country are the codes used common? Eg in US what is the code? Is it common across the country? Is 141 used countries other than UK?
[I am not sure but maybe 141 only works on analog lines?]
Angus
Yes, it's common, but the codes vary between countries. OFCOM specifies 141 and 1470 to block and release CLID in the UK. In North America, NANPA calls them Vertical Service Codes, and uses *67 and
*82. In other countries they use other codes.
R's, John
