Centrex on Key-Norstar
Jun 17, 2005 3 Replies
Jump to replies (3)
I am trying to forward a centrex trunk off site using my Norstar 616 key system, my provider (Telus) uses *72. I have tried link (feature
71) then *72 but no luck.
Does anyone know of a way to forward a Centrex trunk off site using this key system?
thx
Dave Veilleux Planet Telecom Edmonton, Canada
Check to see if the system has trunk-to-trunk transfer enabled. A lot of systems set this feature off to prevent toll-fraud.
Hi Justin,
I checked out the manual and the soft key options that I could find, no luck. I am thinking maybe buy a Centrex set and connect it for forwarding feature only...
Thanks anyway
Cheers
Dave
Just> I am trying to forward a centrex trunk off site using my Norstar 616
