CE-PE interaction
Dec 05, 2004 1 Replies
Does any one know how frames are forwarded from a customer edge switch to provider egde switch in a metro ethernet?
Thanks, Sriharsha
it depends.
you dont normally need to use label switching between CE and PE - so all you need is standard IP over Ethernet.
Maybe 802.1q tags if you need VRF separation?
