Re: Using Two ADSL Internet Connections Simultaneously
Dec 16, 2005 0 Replies
> - NAT in use, and load balancing on a per-connection basis. This
>> automatically balances the return traffic as well, as everyone on
>> the net thinks you're actually two separate independent IP nodes.
> NO, it does _Not_. You cannot change the NAT translation _during_ a
> 'session' (a single TCP connection). And if the 'incoming' data
> characteristics change radically _during_ that session, the 'balance'
> goes out the window.
What part of "per-connection" was unclear?
James Carlson, KISS Network Sun Microsystems / 1 Network Drive 71.232W Vox +1 781 442 2084 MS UBUR02-212 / Burlington MA 01803-2757 42.496N Fax +1 781 442 1677
