Re: Switch Identification
May 22, 2005 0 Replies
Recently I switched service providers for my POTS line. We used to be
> using a WECo 5ESS, with the older line cards (the better sounding
> ones!). I switched to a cable provider and obtained a landline through
> them. It's not VOiP. It is routed through the same switch I used to
> use but it's not homed from that switch. So obviously this makes
> finding the CLLI of the switch alot harder.
> To get to the point, while messing around with the switchhook I got a
> strange busy signal. It's 1600 Hz on for 0.5 seconds, off for 0.5
> seconds. Here's a wav file of it:
> If you have any idea of what kind of switch this is,
> please advise! Thanks.
Obviously, while playing with the hook switch you managed to connect to the gate shack at a construction site- that sound is quite definately a '95 Mack 3 ton dump truck in the process of backing up :).
H.
