Re: Configuring my VoIP box for 988 [telecom]
Jul 23, 2022 Last reply: 4 years ago 1 Replies
have a Poly (sigh) Obi200 using Google Voice (SP1) and PunchAlert (SP2 for >E911).
>So is there something I need to do to make 988 work on my configuration? It
>seems likely, but in my digging, there doesn't seem to be quite the right
>combination of information to figure out *what* I need to do.
When I look at the manual, starting around page 197 it describes the way you define the dial plan, which probably not by coincidence looks just like the way you define dial plans on a Cisco/Linksys adapter.
Somewhere in the config the dial plan for each line is something like this:
(1234;<+>567.;....;911S0)
It's list of digit patterms separated by semicolons. You need to add
988S0 to ths list, which means recognize 988 and put the call through immediately (zero second timeout). The patterns are evaluated in parallel so it doesn't matter where in the list it goes.
This assumes that your carriers know what to do with 988. If not, thie should work, dialing the actual 800 number of the 988 provider instead:
<988S0:180027388255>
If your dial plan still lets you dial local calls with seven digits (mine does) you might want to undo that if you care about being abie to call 988-XXXX numbers in your area code.
R's, John
You might want to post the question over on
in the "VOIP Tech Chat" forum as they still have active members who configure and modify the firmware for the OBI/Poly series of VOIP devices. You can post anonymously or create an account and go on from there.
***************************** Moderator's Note *****************************
A. Because it disrupts the intuitive top-to-bottom flow of a written conversation.
Q. Why is top-posting a bad practice?
Bill Horne Moderator
