ASCII / Baudot Article [telecom]
Apr 22, 2008 4 Replies
Jump to replies (4)
Recently we were discussing these code sets.
There's a very interesting article on ASCII development and comparison to Baudot development and usage from the April 1964 Western Union Technical Review available in our archives. Please see:
[A big thanks to those who donated and scanned the journals to be available for us! Also check out the next story in the same issue on Private Automatic Telephone systems.]
The article goes into detail about the code's subset and why the bits are arranged as they are. There are many technical issues we modern users take for granted but had to be considered by early designers, and this article provides the background. For instance, back then every bit was expensive to handle (electronically or mechanically) and it was desirable to use subsets.
There's also a glossary explaining all the character abbreivations.
At that time, the Federal Govt and Western Union were developing a new internal communication system (ARS) which would use ASCII and 4-row Teletypes (model 33 or 35).
The article notes that Western Union was not planning to use ASCII too much in its own business as the three extra bits seemed to be an unnecessary burden with little benefit. As stated, bits were expensive and back in 1964 that attitude made sense. IBM's own 8 bit EBCDIC code was just announced but machines wouldn't be service for at least a year. Most computers of that era used a 6 bit code, indeed, internally at IBM there was strong protest that the System/360 architecture was unnecessarily wasteful and the older 1401 architecture (6 bit) would do fine for new models.
Hindsight being 20/20, it was probably a major mistake that W.U. didn't embrace ASCII, if not perhaps in 1964, but within a few years as time sharing took root, served by ASCII Teletypes.
P.S. There are interesting pages preceeding the above mentioned article. check out the Teletype keyboard layout:
Also note the Western Union logo used in this diagram, a W/U within orbiting electrons. Use of this atomic symbol was popular back then, before atomic energy got a bad name. RCA used it for its Spectra computers, as did other companies. Back then it was a symbol of modern progress.
W.U. "didn't have a dog in that hunt" as the expression goes. Time sharing, when it was not served by direct terminal-to-computer connection, was served over dialup telephone connections using modems, so it was all a telephone company enterprise.
If I remember correctly IBM participated in the ASCII standardization effort but protested all along. Suddenly IBM just withdrew all its objections and the ASCII standard went through. Then IBM announced EBCDIC; and it was pretty obvious they hoped to use their market share to make EBCDIC the de-facto standard and bury ASCII.
The point of contention was the relationship between the communication code and the Hollerith punched card code. The most straightforward translation of Hollerith into a binary code leaves some gaps in the middle of the alphabet. There is a gap of seven characters between i and j, and another gap of eight characters between r and s. This comes about because a through i are mapped into 1 through 9 in Hollerith, with some "zone bits" to distinguish them from digits. And then j through r are similarly mapped into 1 through 9. EBCDIC preserves this gap, and allows for simple logic circuits to translate between Hollerith and EBCDIC. The gap is distasteful to have in a code because it upsets the "collating sequence", the sorting order of characters - you'd like to have the alphabet be contiguous with no odd characters stuck in the middle. And there were not enough characters available in seven-bit ASCII to just leave unassigned gaps in the middle of the code.
In the end it was all so trivial because a mere 256 bytes of memory could contain a table to translate between one code and the other. But IBM seemingly had reservations about using even that much memory for code conversion - their highly successful 1401 computer was produced in a model having merely 1400 seven-bit characters of memory in total.
The U.S. government had insisted that ASCII would be a requirement for future data processing equipment purchases. Therefore in System/360 IBM included an "ASCII mode" bit in the machine which did something fairly inconsequential - so much so that in System/370 they eliminated the bit.
Other computer manufacturers were rather stuck with their 6-bit character codes, and the industry standard 7-track magnetic tape. (6 bits plus vertical parity) IBM and later the others produced nine-track magnetic tape equipment; but at first there was need to read and write 7-track tapes with EBCDIC, which required some bit-stomping.
Previously on this topic it was said that W.U.'s big weakness was in that 'last mile' to the customer's premises--it did not have much of a local loop plant and depended on the Bell System. Is it safe to assume that, say a stock broker who had a ticker and some newswire Teletypes and perhaps a Telex machine, used Bell wires between the office and the nearest W.U. switching facility or line center?
But what about very large government, corporate, and industrial facilities located in cities? Didn't W.U. have a network of its own loop plant to serve such organizations? (I recall seeing lots of WUTC manholes in downtown Phila). What about all the companies that had Desk Fax and 'turn-knob' message requesters, weren't they connected by direct wire? Didn't the company ADT start out by providing local loop?
Anyway, I'm surprised W.U. didn't try to jump in and grab some of that early time sharing business through its own network. The articles in the Tech Review seemed to indicate they were well aware of computer based messaging and were developing interfaces for it, both for their own purposes and to serve customers.
Thanks.
