Can I use CT100 coaxial cable for CCTV?
Sep 14, 2005 1 Replies
John
No problem at all CT100 is a good quality 75 ohm low loss coaxial cable as long as you get the correct plugs for the cable you will be fine. John.
I have some spare CT100 coax cable and want to run it (along with a twisted pair for 12VDC power) to some CCTV cameras from a DVR card.
Is it OK to use CT100? This type of cable is normally installed for digital TV reception. It has 75 ohm impedance.
Thanks
