Power Loss Alert / Alarm
May 11, 2006 2 Replies
Can anyone provide a web link (UK if possible) for a device that makes an audible alert when the power is lost to it. I'm looking for a simple plugtop size device that plugs into a standard UK 1363 mains socket and makes a buzz / sound when power is lost to it.
Thankyou in advance.
Most UPS systems will "buzz" or "beep" when the power fails. You also get the added benefit of still being able to use the device it's plugged in to for a while.
Thanks, indeed I have considered a UPS, but too expensive and 'heavy', I also need some degree of mobility.
After a long time searching through SE's and various forums, seems some people have previously bough such a device =A310-=A320, simple, small, and mobile (plug in where you want), they have said so, but cant recall or point me towards a contact or web site that sells them.
Any more thoughts?
Thanks!
