Need Programming Help
Sep 01, 2006 0 Replies
I have a Safewatch Pro 3000EN (Ademco-Vista 15P) wireless system with two 6270 keypads.
I want to be able to set up a macro key to bypass my upstairs motion detector. My baby's bedroom is at the opposite end of the hall from my bedroom and the hall is covered by the upstairs motion detector. I have
to bypass it every night and it is tedious and time consuming.
I checked my manual and it says 'the installer must first activate this
function using the *57 Function key Menu Mode before macros can be assigned'...whatever that means, and I can't tell if this was done or not. I checked the programming guide and now I'm even more confused. The system was pre-programmed by someone else.
I figured out the installer code and know the number assigned to the motion I want to bypass, but don't have a clue how to check if the macro function was activated or not, much less what to do from there one way or another! I'd like to assign the bypass of this particular motion detector to a macro key, if possible.
I don't know where to even start!
Any help would be greatly appreciated.
Thanks.
