Omnipro 2 with a OnQ 4 branch ALC board
May 31, 2005 1 Replies
Hello, I have an Omnipro 2 with a OnQ 4 branch ALC board. I installed it just
like the instructions said. I dont know how to control it using the dealer software for Windows ver 2.4a. The status light on the alc board is blinking. How do you tell the Omnipro the the expansion alc board is installed?
Thanks in advance,
Jeff
Enter setup, # for installer, 7 for expansion. Scroll with the down arrow, untill you find the module # that matches the jumper on the alc board, press # scroll down or up arrow until you find ALC.
In Pc Access, setup, installer, expansion.
