Controlling thermostat over the web
Aug 04, 2006 5 Replies
Jump to replies (5)
I don't want any fancy home control system. I now have two Carrier thermostats that ConEd supplied to me that have web control. In return for getting these they are allowed to cycle off my compressor. The problem is they cycle everybody off equally. I purposedly put in an undersized unit on the roof. I'd rather it be dry and not cold and clammy. But with ConEd cycling it off my temperature stays in the mid-80s. So they have to go.
Carrier has this model:
Which states it has remote access for Internet. You can't get much information on it from Carrier. It is new and the reps don't know much. And they like to steer you to you dealer for any technical questions.
Are there any other options?
Don (e-mail link at home page bottom).
Look at these:
If you really want to be simple and inexpensive, You can make a servo based controller like below and control it over the internet.
Well that certainly meets his criteria for not being "fancy!"
Too simple. I do expect a seven day schedule with four periods per day.
If your computer has a scheduling application that can run applications at the desired times, then it can control the servo when desired. If your computer is connected to the internet, the servo can be controlled over the internet if desired. This is more geared for DIY types that like to save $$$.
