whizlab question
Dec 16, 2005 1 Replies
Hi all, I'm going to attend an application server architect exam. In this exam there are some network/security questions too.
One of these is the following:
What type of firewall will you use to the validate the application protocol of a network communication? =B7 a. SSL =B7 b. Packet Filters =B7 c. Stateful packet Filters =B7 d. Proxy
I think, since application protocols are tied to a known port it could enough a static packet filter, that checks if the packet is going through one certain port.....
What do you say ?
Thanks a lot Francesco
An application protocol would be, for example, that an SMTP "RCPT TO" command does not occur until after a "MAIL FROM" command. Static packet filters are not able to check that.
SSL is not a firewall: it is a secure transport mechanism. It doesn't care whether what is sent over it matches the application protocol or not.
