Website or GUI Tool for IP Forensics?
Jan 12, 2007 4 Replies
www.BradReese.Com
Hi Will, You may wish to investigate DNS Stuff: DNS tools, DNS hosting tests, WHOIS, traceroute, ping, and other network and domain name tools well as Domain Dossier - Investigate domains and IP addresses Brad Reese Cisco Tools
Website or GUI Tool for IP Forensics? open original image
Is there a good website I can plug an IP into, and have it spit back the output of:
- Whois on the IP
- Reverse DNS lookup on the IP
- Whois on the domain that comes back from the reverse lookup etc
The web site gets brownie points (and I might even pay them a subscription) if I can dump in a list of IPs and have them come back with the above for all of those IPs.
Hi Will,
as well as
Sincerely,
What's wrong with just using whois and nslookup/host?
cu
59cobalt
You need to type the pipe symbol '|' to transfer the data from one tool to the other, which seems to be too complicated for the users with DEP (data execution prevention -> separation: mouse input = command, keyboard input = data). *SCNR*
Hi Will,
Try this source:
Sincerely,
Brad Reese
2007 Cisco Salary Rates
