SuSeFirewall2 and range of addresses without using mask
Dec 17, 2004 1 Replies
Hello,
Does anyone know how to setup a range of addresses in a block to allow certain protocols access without adding them individually (like 10-30) or using a netwmask?
I've tried these examples on my internal network under the masquerade area using the SuseFirewall2 Webmin module:
10.0.0.100:150,0/0
10.0.0.100-150,0/0
10.0.0.100-10.0.0.150,0/0
10.0.0.100:150,0/0,tcp,80 (web only for testing restricted access)
and some variants.
Can anyone help?
Thanks!
Greg
Sure. You can't. iptables (which SuSEfirewall2 uses) only allows netmasks.
On the other hand, you can reduce any range into a few subnets. For your example, you would need 7 entries (fewer if you could include a few extra IP addresses on each side).
But really, you would want to learn using subnets instead of ranges -- they're used everywhere, and the routing/filtering is done at the network level. Ranges are artificial, and not native to how networks work.
Regards,
