Some help interpreting log snipped please?
Dec 03, 2005 9 Replies
Moe Trin
Given the concept of a "personal firewall", that's probably a good solution. 1. UDP Source address _can_ and usually IS faked. 2. The last time I bothered to look at the UDP crap that was not DNS (to and from port 53 on the nameservers my systems are configured to look to), I…
I'm running kerio 2.1x. Have rules defined for small number of internet apps only, with fw set to block anything else -all protocols,even dns, unless explicitly stated for a particular app (dns rules are specified for each app).
This is a new ISP, an I am getting alot of UDP blocked packets in the log from it and from all over the globe. When the block all else rule is at the end of the ruleset and set to log, I get the snippet shown below.
The fw reports three ports listening p 137-139 for nbname, nbdatagram and nbsession, yet no data exchange for these ports presumably due to my block all else setting.
If I explicitly write a rule to block udp send and receive at the beginning of the set, I cannot get get anything to communicate on the net, but when the fw is just set to block all else I can communicate, but I still see these blocked, mostly udp to p137 entries in my logs.
Why am I getting udp blocks incoming and outgoing from addresses from other networks? Please take a look at the snippet below and advise what is going on and if this is normal or not?
What????????????????????????
Duane :)
  2. The last time I bothered to look at the UDP crap that was not DNS (to and from port 53 on the nameservers my systems are configured to look to), I was seeing over a thousand hits a day - mainly aimed at my ports 1025 to 1035. Inspecting representative packets showed it to be messenger spam (fake windoze warning messages directing me to this or that web site to get my computer "fixed"). As I'm not stupid enough to be using windoze, I knew these packets could not be from my computer.
Snippit not found. I rarely (like once a year) bother to log packets that have been dropped. My systems work, and have not been r00ted or
0w3n3d, so my firewall must be working correctly.
You have windoze sharing turned on. You probably also have windoze messenger enabled. Turning both off would help, do a google search to find out how.
Because it takes precedence over the other rules - and is blocking DNS
After turning off sharing, I'd suggest turning off this log function too.
Clueless people running a fools operating system. It's amazing that the aftermarket is full of firewall programs that can be used by the average user, and more amazing that they are needed because microsoft can't seem to write the same quality programs. Still, the sheep keep buying it, and that's all that matters to microsoft.
Check the help screen, and try again - NO MORE THAN 30 LINES, NO MORE THAN
2400 CHARACTERS PLEASE.
Old guy
snipped-for-privacy@painkiller.example.tld (Moe Trin) wrote in news: snipped-for-privacy@compton.phx.az.us:
I thought windows sharing was part of their network protocols and I only have dialup tcp/ip installed. But I will double check, this is a new machine/setup.
Makes sense.
This OS is only installed as one of what will be several OS's including BSD. Only reason I installed wincrap is that there are some software packages that only run on this and I am most familiar with it. But my intention is to shift to another OS ASAP.
I thought I just forgot to add it. Here it is, sorry for the confusion; can you take a look and confirm what is happening here?
BLK:In TCP,4.240.150.93:3421->localhost:135,own:noowner BLK:In TCP,4.240.150.93:3421->localhost:135,own:noowner BLK:Out UDP,localhost:137->4.240.150.93:137,own:C:\\WINDOWS\\RUNDLL32.EXE BLK:Out UDP,localhost:137->4.240.150.93:137,own:C:\\WINDOWS\\RUNDLL32.EXE BLK:Out UDP,localhost:137->4.240.150.93:137,own:C:\\WINDOWS\\RUNDLL32.EXE BLK:Out UDP,localhost:137->209.244.0.3:137,own:C:\\WINDOWS\\RUNDLL32.EXE BLK:Out UDP,localhost:137->209.244.0.3:137,own:C:\\WINDOWS\\RUNDLL32.EXE BLK:Out UDP,localhost:137->209.244.0.3:137,own:C:\\WINDOWS\\RUNDLL32.EXE BLK:In TCP,4.240.150.93:1947->localhost:445,own:noowner BLK:In UDP,218.66.104.208:44753->localhost:1028,own:E:\\Kerio\\PFWADMIN.EXE BLK:In UDP,218.66.104.208:44753->localhost:1030,own:noowner BLK:In TCP,4.240.123.247:4969->localhost:139,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE BLK:In UDP,61.233.41.180:37908->localhost:1028,own:E:\\Kerio\\PFWADMIN.EXE BLK:In UDP,61.233.41.180:37908->localhost:1029,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1033,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1030,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1031,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:4257,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1032,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:4257,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1028,own:E:\\Kerio\\PFWADMIN.EXE BLK:In UDP,61.233.41.180:37908->localhost:1030,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1031,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1029,own:noowner BLK:In UDP,61.233.41.180:37908->localhost:1033,own:noowner BLK:In TCP,4.240.123.247:4969>localhost:139,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE BLK:Out UDP,localhost:137->218.66.104.208:137,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE BLK:Out UDP,localhost:137->218.66.104.208:137,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE BLK:Out UDP,localhost:137->218.66.104.208:137,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE BLK:Out UDP,localhost:137->4.240.123.247:137,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE BLK:Out UDP,localhost:137->4.240.123.247:137,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE BLK:Out UDP,localhost:137->4.240.123.247:137,own:C:\\WINDOWS\\SYSTEM\\RNAAPP.EXE
Just background noise from the Internet.
UDp traffic is usually NETBIOS attacks/scans, Microsoft WIndows Pop Up spamming, and a few other minor ones. Welcome to why people use firewalls.
If you run any peer-to-peer sharing client (especially gnutella or bittorrent clients) you will draw a flood of traffic to your internet address. It will be a mix of udp or tcp depending upon client/protocol.
wats>I'm running kerio 2.1x. Have rules defined for small number of internet
Dialup is networking. Microsoft makes no differentiation between dialup, wireless, or Ethernet. They assume you want to share your system with any computer you can connect to in any way.
Include details that the people need - O/S, distribution and version, and so on. While there are only a handful of BSDs (such as FreeBSD, NetBSD and OpenBSD), there are at least 20 different branded UNIX, and over 380 Linux distributions - never mind the Mac O/S. All have different warts.
OK, I put this into a file so I could look at it - lets look first at the sources:
[compton ~]$ grep In ZZZ | cut -d',' -f2 | cut -d':' -f1 | sort -un 4.240.123.247 4.240.150.93 61.233.41.180 218.66.104.208 [compton ~]$
The two 4.240.x.x addresses resolve to Dial1.Phoenix1.Level3.net which is a point of presence provider (they rent dialup service to ISPs - here, this is the Phoenix Arizona market). The other two are Chinese blocks.
61.232.0.0 - 61.237.255.255 is the China Railway Telecom Center, while 218.66.0.0 - 218.67.127.255 is CHINANET Fujian province network. While both are official arms of the Chinese government (Railway Administration and Army respectively), they act as commercial ISPs, providing connectivity to Chinese businesses. Most of what we see outside of China is fast buck artists selling IP space to anyone. That mainly means spammers. [compton ~]$ grep Out ZZZ | cut -d'>' -f2 | cut -d':' -f1 | sort -un 4.240.123.247 4.240.150.93 209.244.0.3 218.66.104.208 [compton ~]$
The new one here (209.244.0.3) is resolver1.level3.net, a name server. The Chinese stuff is all windoze messenger spam - not much you can do to prevent it from wasting your bandwidth (my recent experience, it's about
1000 packets a day - about a half megabyte). All you can do it to DROP (ignore) the packets. While I call this 'Chinese', UDP source addresses (especially messenger spam like this) are often faked. Last month, I ran logging for a week (tcpdump -n udp and not port 53 >> /tmp/udp.watch) and while looking at the claimed source addresses, noted such blocks as 1.x.x.x and 94.x.x.x, neither of which were ever released by IANA.
The stuff between you and the two 4.240.x.x dialups is two windoze boxes attempting to share. I'd strongly recommend disabling that. Then you will be left with other systems waving their undies at you on ports 135, 137-139 and 445 yelling 'Hello Sailor'. Best thing to do there is to block it, either DROP (ignore) or REJECT (reply with a 'FOAD' packet).
Bottom line - another day contaminated by open windoze boxes and messenger spam. Nothing new.
Old guy
Thanks very much Old guy for the detailed analysis. Eventually I will put up a hardware firewall once I get the other OSs installed. But Kerio has done pretty good by me so far. Glad to know the Chinese commies aren't sleeping under my bed, haha.
(next I have to figure out why this milan newserver is run by such a bunch of jerks)
][compton ~]$ grep In ZZZ | cut -d',' -f2 | cut -d':' -f1 | sort -un ]4.240.123.247 ]4.240.150.93 ]61.233.41.180 ]218.66.104.208 ][compton ~]$
][compton ~]$ grep Out ZZZ | cut -d'>' -f2 | cut -d':' -f1 | sort -un ]4.240.123.247 ]4.240.150.93 ]209.244.0.3 ]218.66.104.208 ][compton ~]$
Things are not completely perfect. Notice that your system is trying to talk to the two dialins and one of the "Chinese" addresses. This implies that traffic got past your "inbound" filter. This could be a logging issue where your firewall is trying to ask the remotes what their name is.
Many, perhaps most, of the spammers are either Russian or Yank - mainly the latter. They're merely taking advantage of the dirt cheap hosting in Asia. Often, the sites that I see being spamvertised (I'm in the USA) are actually in the US (Florida, Texas, Washington state or California seeming to be listed most often).
What's wrong with your ISP's server?
Old guy
Windows likes to talk to itself.
Instead of concepts like Unix-Domain sockets, MS binds local stuff to (of all things) 127.0.0.1. so allow 127.0.0.1 i/o tcp/udp all ports as a first rule
to get print/file sharing, only allow local address from your LAN allow 192.168.0/32 i/o tcp/udp ports 135-139,445 as a second rule
the deny from the internet can go directly under rule 2 deny all i/o tcp/udp ports 135-139,445 and you don't need to log it either.
leave the deny all all all at the bottom and log these to see who's attempting what.
Network aware computers tend to do so.
There's nothing _wrong_ with using 127.0.0.1 (or any address in 127.0.0.0/8 for that matter) AS LONG AS it's only on the loopback interface. In another newsgroup, there's a person complaining about packets coming in from other ISP customers with a source address of 127.0.0.1 - through the cable modem. While the operating system should be smart enough to realize that such a packet is a waste of bandwidth and ignore it, not all do. RFC2827 recommends filtering such traffic (along with other non-sensical addresses like 169.254.0.0/8, and perhaps 10.0.0.0/8, 172.16.0.0/12 and 192.168.0.0/16 if your ISP doesn't use these for internal services).
1878 Variable Length Subnet Table For IPv4. T. Pummill, B. Manning. December 1995. (Format: TXT=19414 bytes) (Obsoletes RFC1860) (Status: INFORMATIONAL)
A /32 is a host address, and thus should have a fourth octet in the address. Rather than specify 192.168.0.0/24 (the network 192.168.0.x), the setup should refer to actual address block used on the LAN - not all people use
192.168.0.0/24.
Ignoring 135-139,445 from the Internet is a great idea, but rather than blocking this or that port - block ALL, and only _allow_ specific stuff you need to allow. A home user should not be allowing any services IN (with the possible exception of 113/tcp - required by some mail servers).
Logging is only needed when you are changing things. If you add a new service and it doesn't work, turn on the firewall log which may explain why. On the other hand, who gives flying f**k if every computer in $COUNTRY is trying to connect to a trojan you haven't installed. Your firewall is blocking it - ignore the noise, stop wasting disk space and CPU cycles, and get on with your life.
Old guy
