securing a database from DMZ traffic
Jul 20, 2007 2 Replies
Most relevant reply
Leythos
A typical database/web layout has the database servers in the LAN with the Web Servers in the DMZ. You open the port(s) needed for database communications between the Web Servers and the Database servers through the firewall DMZ>LAN, and only to those IP/Ports. You do not use…
We are in the process of creating a DMZ for our web servers. Currently our web servers have sit on our internal network. Moving the web servers to a DMZ is the easy part, but what I am not sure about is how to secure our database. I do not want it to sit the database on the DMZ, but I also do not want to allow my DMZ to access the internal network to hit the database. Does any one have a suggestion that i can lookinto. We have a Cisco ASA5510 firewall and muliple Cisco 3560g switches. Any suggestions would be appreciated
Thanks CR
A typical database/web layout has the database servers in the LAN with the Web Servers in the DMZ. You open the port(s) needed for database communications between the Web Servers and the Database servers through the firewall DMZ>LAN, and only to those IP/Ports. You do not use Windows Authentication in your database/web application, you would use SQL Authentication.
If you network is based on Microsoft platforms you want to make sure that your web servers are NOT part of your active directory structure and that you only open the Database communication ports from the web servers to them.
snipped-for-privacy@gmail.com schrieb:
Hi, Access from the DMZ to the internal Lan should never be directly allowed. I recommend to create 4 security levels on the ASA:
0= outside 30= DMZ 60= Database 100= inside
30 and 60 shall be on different physical interfaces of the ASA, but if you have only 3 interfaces you can also use VLANs for DMZ and Database; or upgrade your ASA. Then create the corresponding rules.
bye
Christoph
