Hi all, I'm trying to figure out why using a router (zot ia400) makes Kazaa-lite have less successful download-connections and slows even the few working downloads down. Of 20 selected vids normally 5-10 downloads happen, but with the router only 1 or 2 download really start!?
I've disabled the routers build-in firewall and allow everything, see lower... This doesn't make it better!
I've read that I should forward the ports Kazaa-Lite is using, but Kazaa-Lite seems to open many random ports for every selected download!? Strange differences between the open ports between the router-monitor and the netstat comment, see lower...
So how do I solve this?
--------------------------------------------------------------- Routers settings Enable Firewall Protection : No Default Action for LAN-to-WAN Access Rules : Forward Number of Incomplete TCP Connections Allowed in A Minute : 100 Self-Protection Time When A DoS Attack Is Detected : 1 Minutes Allows TCP/UDP Port #139 to Pass Through : Yes Allows MultiCast to Pass Through : Yes IP Source Routing : No Enable Remote Management to This Router : Yes Respond to Ping from WAN Side : Yes
------------------------------------------------------ Router access monitor PC's IP Address Internet Activities Port No.
192.168.1.124 65.34.190.189 3856
192.168.1.124 83.84.56.31 2844
192.168.1.124 195.130.131.253 80
192.168.1.124 192.168.3.10 2418
192.168.1.124 192.168.0.11 1625
192.168.1.124 24.31.137.173 1929
192.168.1.124 192.168.123.150 32656
192.168.1.124 66.249.85.104 443
192.168.1.124 64.233.167.104 80
192.168.1.124 84.194.119.169 2811
192.168.1.124 192.168.0.2 2555
192.168.1.124 66.249.85.99 80
--------------------------------------------------------------- C:\\Documents and Settings\\x>netstat Active Connections Proto Local Address Foreign Address State TCP asus-amd:2106 192.168.1.1:http TIME_WAIT TCP asus-amd:2107 192.168.1.1:http TIME_WAIT TCP asus-amd:2111 192.168.1.1:http TIME_WAIT TCP asus-amd:2112 192.168.1.1:http TIME_WAIT TCP asus-amd:2113 195.130.131.253:http TIME_WAIT TCP asus-amd:2115 64.233.167.104:http ESTABLISHED TCP asus-amd:2116 64.233.167.104:http ESTABLISHED TCP asus-amd:2118 192.168.1.1:http TIME_WAIT TCP asus-amd:2119 192.168.1.1:http TIME_WAIT TCP asus-amd:2125 192.168.1.1:http TIME_WAIT TCP asus-amd:2129 64.233.167.104:http ESTABLISHED TCP asus-amd:2130 64.233.167.104:http ESTABLISHED TCP asus-amd:2131 d54C277A9.access.telenet.be:2811 ESTABLISHED TCP asus-amd:2133 192.168.0.2:2555 SYN_SENT TCP asus-amd:2134 192.168.0.11:1625 SYN_SENT
