Router Bombardment
Jul 10, 2008 1 Replies
Hello, I'm having router problems. lately my router has been crashing every 10 minutes or so and when i check the logs i notice HUGE bombardments of blocked UDP Packets.
See: [INFO] Thu Jul 10 12:23:33 2008 Blocked incoming UDP packet from
218.102.96.90:1041 to 71.87.34.47:14953 [INFO] Thu Jul 10 12:23:32 2008 Blocked incoming UDP packet from
76.175.33.206:51569 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:32 2008 Blocked incoming UDP packet from
65.175.193.118:55032 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:32 2008 Blocked incoming UDP packet from
24.127.108.151:13574 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:31 2008 Blocked incoming UDP packet from
216.218.114.65:16005 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:31 2008 Blocked incoming UDP packet from
71.251.206.116:24821 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:31 2008 Blocked incoming UDP packet from
82.67.1.92:12477 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:31 2008 Blocked incoming UDP packet from
68.205.249.63:41550 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:31 2008 Blocked incoming UDP packet from
216.183.56.196:29841 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:30 2008 Blocked incoming UDP packet from
76.94.163.89:23769 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:30 2008 Blocked incoming UDP packet from
76.188.219.106:22100 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:30 2008 Blocked incoming UDP packet from
71.202.127.19:49699 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:30 2008 Blocked incoming UDP packet from
74.193.143.211:19285 to 71.87.34.47:28059 [INFO] Thu Jul 10 12:23:30 2008 Blocked incoming UDP packet from
81.207.75.118:32000 to 71.87.34.47:28059
Although this is happening all the time, it crashes for some reason. (^i believe this isnt during a crash) Its severely annoying and idk what to do. halp.
Am Thu, 10 Jul 2008 11:32:10 -0700 schrieb mensk88:
Sniff one of thost packets and look inside, usually a router has nothing to do with the packet payload it's just looking in the ip fields for src and dst.
