PIX Configuration Help !
Aug 28, 2006 2 Replies
PIX Configuration Help ! open original image
Hi Group,
I need to setup X-Auth and Radius (authentication only) on the PIX for couple of users who will be connecting remotely through VPN Clients with Pix.
LAN (Radius other servers)------PIX-----ADSL Router---------Internet---------VPN Clients
Radius will be configured on Windows 2003 server and IIS service will be enabled as well. Below is also pasted the current configuration.
PIX Version 6.3(1) interface ethernet0 10baset interface ethernet1 auto nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password Xj encrypted passwd DI encrypted hostname Pix fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol ils 389 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 names access-list out-in permit ip host 192.168.2.1 any access-list out-in permit icmp any any echo-reply access-list out-in permit tcp any host x.x.x.27 eq smtp access-list dialin permit ip 192.168.1.0 255.255.255.0 host 192.168.2.1 pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside x.x.x.26 255.255.255.X ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm pdm history enable arp timeout 14400 global (outside) 1 x.x.x.28 nat (inside) 0 access-list dialin nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) x.x.x.27 192.168.1.10 netmask 255.255.255.255 0
0 access-group out-in in interface outside route outside 0.0.0.0 0.0.0.0 x.x.x.25 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local url-server (inside) vendor websense host 192.168.1.9 timeout 10 protocol TCP version 4 filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 no snmp-server location no snmp-server contact snmp-server community royalh no snmp-server enable traps floodguard enable telnet 192.168.1.0 255.255.255.0 inside telnet timeout 5 ssh timeout 5 console timeout 0 url-block url-mempool 1500 url-block url-size 4 terminal width 80
I have looked at above mentioned 2 configurations but not sure if i am right track or not. Any advice will be highly appreciated to get started with this work.
Thanks in advance.
Post your question here:
Regards Colin.
