Packets not forwarded even though ports open
Feb 28, 2005 1 Replies
I'm working with a Sonicwall TZ170 Unlimited with the most up to date firmware (3.0.0.4). I have the TZ170U setup to allow all traffic through the WAN port on a specific IP address for an access rule. When trying to get through the WAN port from that machine that has that IP address, it will not allow traffic through. If I go back to a Sonicwall SOHO2 with the most up to date firmware, everything works fine with the exact same access rule configuration. Has anyone seen an issue like this with the TZ170 Unlimited?
You are allowing all traffic to a certain address inside the firewall? Have you put this in the DMZ interface?
