Netgear FVS318v3 Issues
Dec 04, 2005 4 Replies
Jump to replies (4)
Hi there, I wonder if anyone can help me out with an issue that I am getting with my firewall. From the moment I start the firewall up, the log begins to fill up with the following message:-
Sun, 2005-12-04 17:27:42 - ICMP packet - Source: 192.168.1.1 - Destination:
192.168.1.2 - [ICMP Type: 8 Code: 0, Received
ICMP type 8 is an echo request, however, the destination IP does not exist on my network and consequently, there can be no reply to the echo request. The log simply fills up with this error and eventually the router crashes and needs rebooting (which is a pain as the router is in the attic). If anyone has any ideas about how to get around this, I would be extremely grateful.
Thanks
Change the router to 192.168.5.1/24 and see if the error is the same.
Also, update the firmware.
Do you have a wireless access point anywhere in the network? If so, turn it off and see if you stop seeing these issues.
Cheers Leythos,
I'll give it a go.
Leythos,
It would appear to be my Wireless Access Point. Shutting that down has resolved the problem.
Thanks for your help
Before you get any farther, you need to set WPA/PSK on your access point or it's going to happen again - not to mention all of the people that can freely access your network.
For the Access Point, get on the vendors site and findout how to enable WPA on it. This will keep others out of your network unless they have your key.
