Need advice
Nov 07, 2006 10 Replies
Jump to replies (10)
Hello I need a recomendation. I have a medical practice that has 4 remote offices all with broadband connections. I currently have Linksys routers/gateways in all offices. I want a slightly better product at these offices that will allow vpn connections etc. I have looked at Sonicwall, Symantec etc. Any suggestions?
Most Linksys stuff is linux-based with many alternative firmwares available, including some with excellent VPN support.
In any case, Symantec = teh bad!!1
What about Netopia stuff...ie Netopia 3347?
Sebastian Gottschalk wrote:
Pick anything that's been certified by ICSA Labs and you'll be happy.
You may wish to investigate Toms Hardware Router Comparison Chart:
and individual respective Router Manufacturer Forums:
Sincerely,
Brad Reese Cisco Repair and Hardware Troubleshooting
What does this mean?
Available in 10 node configuration; not upgradeable Concurrent connections: 2,000
wrote:
Some of the LINKSYS gateay comes with VPN Enabled Use that that is the most secure usning IPSEc and IKE.
CK
jawdoc wrote:
You may also wish to investigate the Cisco Small Business Network Designer:
http://64.224.10.185/sbnd/child/1.0/index.asp as well as the Cisco Solutions Designer:
Sincerely,
Brad Reese Cisco Tools
No, he's not "good to go the way he is", as he's not provided any details.
He's not specified what "Linksys" router that he's using, and unless it's a VPN Router it won't do site to site VPN. Most of the Linksys units are not firewalls, they are simple NAT routers only.
He's specifically asked for a device that will allow VPN connections - assuming that he wants something that users can VPN into the device, not VPN through the device, then he's going to need a quality device, not a rinky NAT router.
Almost every device on the ICSA Labs list qualifies for what he wants, under the "certified firewalls" group.
Now, do you have ANYTHING constructive to add?
He is good to go the way he is . What the hell are you talking about here ????
