Limiting connection scope
May 04, 2006 12 Replies
Jump to replies (12)
I'm looking for a workstation product that can be used to limit, under administrator control, which hosts a workstation can connect to. Windows firewall and alternatives are all user-oriented, and concerned with protection when Internet browsing, and so don't answer this problem - although some provide outbound filtering, none of them appear capable of preventing user interaction with the firewall function. This workstation is located on a network, boundaried by a firewall, and is to be used for connecting to one system only, in a DMZ. It must be prevented from connecting to other hosts within or outside the network. Anyone have suggestions?
Take the packet filter in Windows' kernel.
You don't need a product at all for this purpose. Just modify the routing table, and have a single host route to this box only.
Yours, VB.
Thanks Volker, but I don't think this will achieve what I'm looking for. We want to prevent a workstation from connecting to any hosts other than the intended one. Isn't the routing table dynamic? Even if we edit it, won't it get re-written?
If you don't have routing protocols: no.
Yours, VB.
assuming the workstation is not running OSPF or RIP or other dynamic routing protocol, then no, it is not really dynamic. (OK< It CAN change if it gets an ICMP redirect sent to it, but how likely is that?)
So for instance, (assuming it is a windows box) and you want to blackhole all connections to 192.168.xx.xx local nets, you could do something like "route add 192.168.0.0 MASK 255.255.0.0 "
Can be disabled easily.
But unlikely enough that I wouldn't bother.
Ipsec policies will do that for you. Setup the filters so your workstation can only connect to one destination.
Wayne McGlinn Brisbane, Oz
On Fri, 5 May 2006 09:27:39 +1000, Wayne spoketh
If there's Domain Authentication involved, remember to allow connections to a DC and DNS server.
Lars M. Hansen
'badnews' with 'news' in e-mail address)
Does that require connection via Ipsec to those services?
Try reading the following:
Wayne
Thanks everyone for your responses to this.
