IP Tables related error
Jul 09, 2005 1 Replies
When i use the Rule:
-A FORWARD -p tcp -m multiport --dport http,https -o eth0 -i eth1 -m time --timestart 12:30 --timestop 13:30
i get the error: Couldn't load match `time':/usr/lib/iptables/libipt_time.so: cannot open shared object file: No such file or directory
Please help jZZ
RTFM
Though the man page of iptables mentions the time extension for match that one is - unlike other extensions of match - patch-o-matic stuff and therefore not part of the standard kernel. You have to patch your kernel if you want to use it.
In another posting you said, that you are looking for a job in the security business. I might sound harsh but if you you really want to work as a security consultant you must be able to solve such a problem by yourself.
Wolfgang
