How to sensibly start IPtables ?
Jul 25, 2004 4 Replies
Bit Twister
What you could have is a script with uses basename to get the name which was used to call it. Example: fn=$(basename $0) You then make two links in the same directories as the S10network link. Example: cd /etc/rc.d/rc3.d/ ls -s /etc/rc.d/init.d/my_iptable_rules S10before_net ls…
Example: cd /etc/rc.d/rc3.d/ ls -s /etc/rc.d/init.d/my_iptable_rules S10before_net ls -s /etc/rc.d/init.d/my_iptable_rules S10network_up
Now a ls S* we see something like S10before_net S10network S10network_up which indicates the order they will execute when the system boots.
Now my_iptable_rules could have a test like
if [ $fn = S10before_net ] ; then (load iptable with a restriced set of rules here) fi
if [ $fn = S10network_up ] ; then (load iptable with some more rules here) fi
Your are correct, should have been ln.
Frap, there goes all my gold stars for the week. :(
I had already disconected fingers from brain while forming the next paragraph in head.
Thank you for the correction.
I have an RH9 Linux system running as Router/FW. IPTables 1.2.9 on it and running happily.
Would the following be a sound idea, as to maintainablility of the IPTables rules and the effectiveness and security of the FW:
Immediately after the running of a script in /etc/rc3.d a partial IPTables script must run, to open up the FW for any necessary ports/protocols/etc. related to that /etc/rc3.d script.
example and problem:
just after running the /etc/rc.d/init.d/named script, the FW must be opened for protocol UDP/port 53. If it is not opened, the subsequent ntpd script would not work, for it opens the FW for a few timeservers, not given by IP number, but by FQN. And it would log a few packet refusals, if not opened immediately.
same goes for other servers, that need specific ports open. (Or, more general, need specific IPTables rules effective): samba, apache, sendmail...
For this, I would make a parallel directory for the partial IPTables scripts (eg. /etc/rc.d/iptables/S08named), which would be controlled by a mechanism incorporated in the /etc/rc.d mechanism (S08named things)
Question is, how would I incorporate this parallel mechanism in the startup scripts and where ?
fr gr Erik
details...
wanted to make sure. Such is the cross we have to carry: colons and semicolons...
thnx for the suggestions. worth a few stars to me :-)
Erik
