How do i Re-direct specific http request to another gateway
Jan 24, 2006 1 Replies
NT17
Why dont you integrate everything in one machine. You could also use commercial software like GajShield and Astaro to achieve this. This will help in reducing complexity and easier management. I have used GajShield extensively and can tell you that it provides the required…
Hi All,
I have two internet connections. One is with static ip and second with dynamic ip.
1st Machine linux with Internet connection and static ip is configured for mailing,vpn. VPN provides the access to corporate intranet site.
2nd Machine linux with internet connection and dynamic ip is configured
using squid,but it cannot access corporate intranet site.
Is there any configuration available with squid or iptables, so that i can re-direct http request for corporate intranet site from
2nd machince to 1st gateway machine .
thanks in advance DK
I have used GajShield extensively and can tell you that it provides the required security feaures like Firewall, IDS, Virus Screen> Hi All,
