Fortigate 100A gateway-to-gateway VPN configuration
Aug 03, 2006 1 Replies
Hi all,
I have 2 x Fortigate 100As, the IP address on the wan interfaces us dynamic IP addresses on both boxes (although the IPs don't change for very long period of time - like either months/years). We use dyndns.org to give it a "fixed" and readible reference point for the not so technical IT managers.
Now, my question is: Is there any easy way to create a vpn connection between the internal interfaces between the 2 firewall boxes? Can the dynamic DNS entries be used on both boxes?
I've tried to follow the Fortinet instructions and I could successfully get the tunnel up using the dynamic dns entry on one side and fixed ip address on the other. But there was no network communication between the 2 networks.
Does anyone have a set of instructions which would actually work which you could share?
Thanks.
James
