Firewall question
Jul 18, 2007 7 Replies
Jump to replies (7)
I just switched antivirus programs a few weeks ago from NAV to Bit Defender and in doing so lost the Norton Internet Worm Protection (i.e the builtin firewall). So I decided to enable the windows firewall and also turned on logging. I also have a FW built in to my netgear wgr614 router which is supposed to be blocking everying except for 3 or 4 ports that I have forwarded. When I check the Windows FW log however I see thousands of entries where the action column is set to "DROP" for ports that shouldn't even be getting through the hardware firewall. For example TCP ports 2188 and 2273, and UDP port 8088 none of which are forwarded. How are they getting as far as the software firewall?
My IP has not changed for several months and none of the IP's below are my WAN IP.
Here's a couple of examples.
#Fields: date time action protocol src-ip dst-ip src-port dst-port size tcpflags tcpsyn tcpack tcpwin icmptype icmpcode info path
2007-07-01 22:32:05 DROP UDP 74.100.189.35 192.168.1.2 45685 8088 42 - -
- - - - - RECEIVE
2007-07-01 20:30:38 DROP TCP 204.2.179.48 192.168.1.2 80 2188 1452 A
4075071033 456793686 27466 - - - RECEIVE
2007-07-01 21:01:54 DROP TCP 69.2.120.39 192.168.1.2 443 2273 1169 AP
2133527059 111240437 18356 - - - RECEIVE
TIA
Close all the ports on the router, don't forward them. And if you don't have the same thing happening, then that should tell that you have ports open, and anything can come down the forwarded open port with unsolicited inbound traffic, that are looking for openings and something listening on the port.
I can't do that. I am not at home and that will cut off my remote access to the network. I just double checked the router and the only forwarded port is for ssh. And even that's secured as much as possible. It's running on a non-standard port, only allows pubkey authentication, and has a 5 second login grace time.
Could these inbound requests be passed through due to SPI? A lot of them have a source port on the remote machine of 80 or 443. Not all, but most. I'm thinking they may be something someone launched from a web browser on my home PC. Like audio streaming for example.
SSH is only an encryption protocol, and I think it means in no way that the port is not attackable, if open.
SPI blocks unsolicited traffic based on a stateful connection being made by a program on a port running on a machine behind the router, in this case using SPI.
If XP's FW is blocking packets, then I think unsolicited inbound packets are being blocked, for whatever reason that may be.
Are you asking if that's the password? Is so, no. Pubkey authentication is like using an SSL certificate in that it uses a public and private key pair. Only the holder of the private key (me) can log on.
