Checkpoint - Deny traceroute through checkpoint firewall
Aug 10, 2004 4 Replies
Most relevant reply
Rob Hughes
Policy, global properties, uncheck accept ICMP to deny all, or set it to before last if you want to be able to deny specific types of ICMP.
Hello,
I have a checkpoint ng r55. I allow a icmp (all types) connection:
Source Destination Service
10.1.1.1 20.2.2.2 icmp permit
The host 10.1.1.1 can ping 20.2.2.2. Okay. When host 10.1.1.1 traces the route to 20.2.2.2, it get a pesponse from the firewall internal and external interface!
Host 10.1.1.1\\> traceroute 20.2.2.2
10.1.1.1 ok firewall_ip ok
20.2.2.2 ok
I do not want that the hosts sees the firewall ip adresses. Can I configure the firewall to drop/reject the icmp (type 8 time exceeded) packet to the host??
I have tried to make an own rule:
Source Destination Service firewall_ip 10.1.1.1 icmp (type 8) deny
alternative any 10.1.1.1 icmp (all types) deny
The "fw monitor" shows me, that icmp packets type 8 flow from firewall_ip to host 10.1.1.1, although I have denied it...
Thanks in advance.
There is something called "stealth rule" , a rule where you put your fw as invisible meaning, it drops all traffic directed to it. (except ev. IPsec, control connections and so on but these are anyway implied rules at checkpoint, so no need to define them explicitely)
Hmmm...thanks, but I don't where to set up the stealth rule? I think the stealth rule is not active or doesn't work.
open your checkpoint installation Open Smartdashboard open help on search tab...enter stealth read the topic, its pretty explicit.
you can also setup a rule to specifically block (drop) ICMP, or just things like Ping, according to just how paranoid you want to be.
Bjoern is alleged to have said in comp.security.firewalls:
