switch reccomendations
Oct 25, 2004 7 Replies
Jump to replies (7)
switch reccomendations open original image
Excuse me if this beyond the normal scope of this group.
But I'm after a 24 port 100baseT managed switch with some form of traffic prioritisation, a couple of 1gig ports, SNMP and VLAN.
I don't usually buy this kind of stuff, I have a budget of £150 (240 ish USD).
Is there a reccomended bit of kit that you guys would normally go for in this sort of instance?
Thanks!
In article , Adie wrote: :Excuse me if this beyond the normal scope of this group.
:But I'm after a 24 port 100baseT managed switch with some form of traffic :prioritisation, a couple of 1gig ports, SNMP and VLAN.
:I don't usually buy this kind of stuff, I have a budget of £150 (240 ish :USD).
That's a pretty tight budget for a 24 port managed switch, especially with the gig ports.
:Is there a reccomended bit of kit that you guys would normally go for in :this sort of instance?
Perhaps you could buy a Baystack 470-24T off Ebay.
There are some very inexpensive 6 to 8 port gigabit unmanaged switches out there, but I doubt they would have vlans, snmp, or traffic prioritization, and 3 to 4 of them would still come out as more than 150 pounds (at least new.) I would not trust any important data to such switches without a thorough test with a packet generator.
How about Netgear? No good?
"NETGEAR's Smart Switch delivers built-in gigabit power at a very attractive price. With the utility of 24 10/100 Mbps ports and 2 copper Gigabit Ethernet ports, growing business networks can benefit from superior performance and keep up with expanding network needs. This high-performance switch connects to servers or a Gigabit-speed backbone for a non-stop
10/100/1000-enabled network that can quickly deliver large multimedia, image, and video files. All 26 RJ-45 ports automatically negotiate to the highest speed and support Auto Uplink technology to make the right link. In addition, an intuitive, Web-browser interface offers simple switch management, making it a snap to monitor switch performance, configure ports, even set up port trunks, VLANs, and traffic prioritization. Shipped ready for use straight out of the box, it delivers switching that's easy to set up and use."
Too cheap to be true?
In article , Adie wrote: |>:Is there a reccomended bit of kit that you guys would normally go for in |>:this sort of instance?
Netgear FS526T ... no SNMP management, which you had stated as a requirement. Also, only has two levels of priority, but that might be enough for you. The article says the switch has 8.8 Gb/s throughput, which implies that it is line rate across all of the ports: (24 x 100 + 2 x 1000) x 2 = 8800 However, the information given there does not establish that it is able to handle 64 byte packets at full rate, only that it could handle full-sized packets at full rate.
Generally speaking, I have seen a fair number of people expressing concerns about Netgear support. I have seen people express concerns about Netgear's return policy (check the details before buying!!).
But if you are such on a limited budget, then you can't be overly fussy about support, or about bit error rates.
Mib browser won't do much good for a switch that does not run SNMP at all. Zippo. Nilch. Nada.
The FS526T does not speak snmp at all. You need an FSM726 for that. But that is out of your budget range.
BTW, many of these lower cost managed switches have been known to have issues with multicast traffic.
Yes, youre right.But I think it will do the job, I just need basic QoS for Voice and for an ERP app.
Regarding SNMP, I should be able to use a MIB browser... I hope.
Anyway, thanks for your input.
Oh.... Bummer!
I imagine it will have issues, hopefully I won't be the one to come accross them.
