STP misunderstanding
Jan 26, 2006 5 Replies
Jump to replies (5)
Imagine your a switch but your not the root switch. A port that traffic come into you from other switches to get to the root switch is a designated port. The port that you send traffic out toward the root is the root port.
BernieM
To add to my other post, check out the first diagram ...
BernieM
STP misunderstanding open original image
Hello, All!
Researching Spanning Tree Protocol raised few questions. What I don't get is the difference between "Root port" and "Designated port" (they seem to be essential), in my opinion thay should be the same, as the meaning is almost same. But according to standard, "Root port" is like an attribute of switch (bridge), while "Designated port" is more likely describes segment (LAN) attribute. On the other hand standard doesn't give distinct defintion of segment. As well I'm not saying about bunch of other confusing terms :-)
So, could you please explain main concept of "Root" and "Designated" ports?
TIA~
With best regards, Roman Mashak. E-mail: snipped-for-privacy@tusur.ru
Every switch will have one root port but may have more than one designated port.
The designated port is looked at from the perspective of a lan segment. That segments way to the root is via the designated port so if a switch has three other switches attached then it will be presenting 3 designated ports ... one for each of those segments. Those switches root ports connect to that main switches designated port.
Did you look at that diagram?
BernieM
Hello, BernieM! You wrote on Thu, 26 Jan 2006 02:58:34 GMT:
??>> about bunch of other confusing terms :-) So, could you please explain ??>> main concept of "Root" and "Designated" ports? TIA~ With best regards, ??>> Roman Mashak. E-mail: snipped-for-privacy@tusur.ru
B> Imagine your a switch but your not the root switch. A port that traffic B> come into you from other switches to get to the root switch is a B> designated port. The port that you send traffic out toward the root is B> the root port. So, DP should exist on every switch in segment, while RP may be only one?
Hello, BernieM! You wrote on Thu, 26 Jan 2006 05:47:26 GMT:
B> The designated port is looked at from the perspective of a lan segment. B> That segments way to the root is via the designated port so if a switch B> has three other switches attached then it will be presenting 3 B> designated ports B> ... one for each of those segments. Those switches root ports connect B> to that main switches designated port. Aha, now it's clear, thank you.
